orlandoclippertim
Thread starter- Joined
- Jun 2, 2011
- 106
My traileris the oregional the boat came with in 1956. The trailer is made of round
tube. On the very rear of it there is a tube which runs left-right and it rotates in
steel bushings. In the middle -where the keel slides - they have a V-roller mounted on
this tube in some stand-offs about 8 inches long. Out at the extreme ends of this
shaft -that is just outboard of the hull - this pivioting tube has a "lever" which sticks
up about 2 feet. On one side it has a 2 inch ring at the end. The other side has no
ring. It appears that if you push foreward on this "lever" it rotates the shaft and tries
to make the rubber roller lift the back of the boat up off the bunks. It appears that this device is designed to lift the hull a few inches off the bunks while it is comming onto the trailer and then pivot down and let the hull bear on the bunks. But what I don't get is what controls the position of this device while the boat is comming on board ........
Are you supposed to tie the lever with the ring into the "up" position untill its all the way
on ????? and then get out and untie the rope ???? Or does the friction and foreward push from the hull keep it in the up position untill the hull stops moving - and then the
device knuckles backwards and down out of the way ....???????????
I remember seeing other old trailers made this way but I never saw one work.
I will be sandblasting and overhauling the trailer soon.
( 56 orlando clipper
My first boat ! :facepalm: Sorry if this is a really obvious question !
Thanks in advance for tollerating a FNG !
Tim in Orlando
Tim in Orlando
