FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
I got a 95 reinell with a 7.4bravo 1 putting thru hull exhaust on it and wanting to put a different cam in it to give it a better sound any suggestions?
So your saying all these boats i hear with a lumpy idle that there going to blow im sure there are some upgraded cams and might have to do carb,intake also thanks for your opinion
What he is saying is that a lumpy sounding motor is the cam "overlap". Thats what makes it sound good, but is bad for a boat as it can suck water into a cylinder from the exhaust. Look around for someone that builds boat engines and ask them what they use. If there are boats in your area that have a sound you like, ask them who built their motor.
On my 4 cylinder, I personally just mounted some big speakers (with a big amp) facing the back of the boat and play whatever exhaust sound I feel is appropriate to annoy people. Don't have to worry about reversion that way. I find that the sound of an idling 1500 HP top fuel motor really seems to impress people.
You can actually watch the water droplets walk UP the exhaust pipes at idle in some cases. If you know you've got a reversion issue, you can manage it (mostly in shutdown procedure), but it's still there and certainly doesn't help.
I had thru hulls on my 17 foot 5.7 powered 4Winns. I KNEW i would suck water so I had a special "Come off plane procedure". Never had an issue but it was stock cam too...
