cadet
sambrosen
I have a 2001 jonhson ocean pro, when it sets mix oil leaks into gas line. why is this happening? Clean out out from line and cylinders and it runs fine once the oil is cleaned out
jonesg
Re: cadet
try again, its impossible to understand what you mean.
"when it sets mix oil leaks into gas line."
say wha?
What is the model number,?
is it using the VRO oil pump?
"Clean out out from line and cylinders and it runs fine once the oil is cleaned out"
clean out out ?
What cylinders?
the piston cylinders?
how do you do that?
Sorry, this is just too incoherrent.
tashasdaddy
Re: cadet
had that same problem, oil would actually fill my carbs.. oil tank was higher than the motor, and would siphon, into the motor. i ended up going premix, and disabling the oil side.
