Cables
SweeperForce
Hello,
I have a teleflex 1700 series controller and really need a new throttle cable. What connection ends do I need for my
150hp 1989 Force? I want to go with TF Xtreme made by Teleflex. I'm thinking I need 3300/33C. Now when I oder this I only get one cable, not both(throttle/shifter) right?
Thanks,
Tom
jerryjerry05
Re: Cables
The cables should be replaced in pairs.
On the cable is the size.Embossed in one end or the other.
(I'm thinking I need) 3300/33C yup thats what you need.
Just figure out what size.
When changing,take pics.
Then as you undo the connectors try to remember the amount of turn on the shifter end.'
Then as you replace them make sure you turn/install them the same way.
