Buy an old Electric Shift?
ezmobee
Re: Buy an old Electric Shift?
Not without the controls I wouldn't!
ThePartsMan
I wondered about that.
So is it more of a $100 parts rig than a good deal on an old reliable motor?
ezmobee
If you had everything and it was running, I'd certainly run it till it wasn't, but I don't think I'd lay out much more than $200-300 for it even then.
tx1961whaler
No. Pretty worthless without controls except to part out. Barely worth 300 in good running order with controls.
1946Zephyr
I would look on Ebay and see if you can find a set of controls cheap enough. If you can, then it might be worth buying a good running motor.
What kind of motor is it and what year?
wilde1j
Way too much for a motor like that. Find a better choice.
jbjennings
I own a '72 50hp johnson.
I agree with everyone above. I can't believe he doesn't have the controls! As said, it's worthless other than for parts without the controls, and the switch for the hydroelectric shift, if it did have controls, had better be working or.....
I wouldn't dare pay ANYTHING for one unless it was running and shifting correctly, and could be shown to do so.
JBJ
samo_ott
I wouldn't buy one. It's bad enough having to deal with electronic ignition let alone electric shift! But I'd listen to someone that had one like JBJ.
jay_merrill
He has a hydroelectric motor with no controls and no title. Do yourself a favor and pass.
seahorse5
The last electric-hydraulic shift outboard made was 1972, which was 38 years ago.
The last electric-magnetic shift outboard made was 1968 - 42 years ago
Do you really want to play with something that old and unreliable?
merc20076
I have a 1966 40 HP electric shift and it still works very good. Ok, it was used in fresh water only and was well maintained. Just put the good oil in (Type C or BRP Premium blend) and change it every season, have a good fully charged battery and it will last long.
But if it doesn't come with the controls box, it's a different story, they are NLA or the rare ones are pricey.
jay_merrill
I have a 1972 hydroelectric shift Johnson 65hp motor that I have run extensively, over the last five years. The difference in my situation and his, is that it was a working unit when I bought it and it came with the remote. He is contemplating a motor that he has no idea to be functional and it is missing a key component.
Further, he lives in a place that requires a title for an outboard and the seller doesn't have it. They all say "you can get it easily." If its so easy, Mr. Seller, go get one and then put the item up for sale.
One of the fears that I would have with this motor, is that it is stolen - no control and no papers just might be, because it was quickly lifted of the back of a boat, in the middle of the night.
jay_merrill
I just found a web page that says Missouri, South Carolins, Texas, Oklahoma, Ohio and Utah require titles for outboard motors. My guess is that there are tons of people in every one of those states who have untitled motors, but the general logic seems to be that they will cut down of the sale of stolen motors.
Back in the day, when outboards were relatively inexpensive, these laws would have been pretty pointless, but in the age of some outboards costing anywhere from $20,000 to as much as $35,000, it doesn't seem to be completely crazy.
richardbrown67@yahoo.com
I have a '71 50hp electric shift. Runs well. Something in the control box must be broken, though, because a previous owner wired in a 3-position toggle switch to put the unit into gear. I push the switch forward for forward, straight up for nuetral, and backward for reverse. I have to make sure my rpm is low when I shift, or admittedly I could wreck my motor. But I've used the motor for 8 summers now, and so far I've had no problems.
I just found out about the special Johnson lower unit oil for these motors, so I bought a bottle. Seems like really lightweight oil. I've been running the heavy stuff for years (80w90) with no problems, but I'll bet it'll run even better on the special oil from Johnson.
gazza2007au
i would buy this engine only if u needed parts im not sure what they are selling for but i have seen the electronic boxes sell for a few hundred and also as cheap as $75 it just depends where u look as for the lower unit being selectronic they are pretty good i have a evinrude 50hp 1971 i just replaced the solenoids in the lower unit i bought a kit from ebay for $200 plus shipping once installed my gears change perfect it is like new the kit came complete with both solenoids, cover,wiring pre wired,rods,and the inserts for the solenoids was a bargain the motor runs very strong and unlike later model engines this engine u just push the buttons to change gear so u wont ever have to worry about worn clutch dogs due to slowly easing into gear as its all automatic once u push the button
redjmp
I have a '70 evinrude lark 50 that runs great! However i do have the selectric control box and without it the motor is useless.
There is something to be said about the coolness of a push button transmission though.
Like an old Dodge Valiant
I wouldn't thumb my nose at one that had good compression and the control box just because its old. As long as it was cheap!
$300 is way too much! Especially no title or controls.
If it had a steel prop I would offer him $75...
However, pistons are NLA and when I burnt a hole in one of mine, I was very lucky that a local dealer had a used one which he gave me.
