Burrs in tilt tube??
Dennis G
After hammering for a week on steering rod to get it out of tilt tube in 1986 2 stroke 150 HP blackmax, it finally came out. There are a couple of nicks on the outside of the rod but not from me hammering on it which leads me to believe that the tilt tube has rough spots inside it. Is the tilt tube galvanized steel? If so, it is probably corroded from past saltwater usage before i bought the boat. Strange, though, that the nicks on the steering rod were not long scratches from pulling it out. Just nicks in a precise small area (1/8" long). Can the tilt tube be honed out without having to be replaced?
Re: Burrs in tilt tube??
Dennis, It is likely the tilt tube is not galvanized. I would clean it up with a pipe cleaner and inspect for burrs not near the edge. The burrs on the edge can be smoothed with a round rile. Then try the new steering cable rod for smooth operation.
Laddies
Banned
A ball hone for brake cylinders will work well also
AMD Rules
Perhaps get some valve lapping compound, or similar abrasive and apply some to the slidiing surfaces of the steering rod and bore of the tube. Slide it in & out, rotate it around, etc. With some patience it should free up after a while. When you're done, clean it to remove any leftover compound and apply appropriate lube/grease.
rodbolt
the ball hone works great. trust me. I use them all the time. snap on has one with a 10" shaft. good luck and keep posting
Dennis G
Thanks for tips. I'll buy a ball hone. Anxious to get my rig back in the water ASAP. Best regards, Dennis G.
