Bill Adkins
Thread starter- Joined
- Sep 27, 2006
- 68
I recently traded work for a 84 Sea Ray 24ft cuddy cab. After a close inspection I noted the bulkhead between the engine room area and the center section that houses the fuel tank has dry rot, what the heck the boat was virtually free. The bulkhead is glassed to the hull on the aft side but not the front side. It is attached to the hull for the full distance side to side but is only used as a floor support in the center. What is the bulkheads purpose, is it a stiffener for the hull shape. Can I replace it in 2 sections and make a joint in the center. the deck is a flush deck so the only way I can see to replace it is in sections. It has a water channel at the bottom between compartments so it being watertight wasnt a consideration when built. There are 2 bulkheads in the boat roughly making the hull three seperate areas. Any info would be highly appreciated as I am trying to formulate a work plan. Thanks ahead of time.
Bill
Bill
