I'm converting this 15' boat into a little bass boat, and am going to build raised casting decks. I am not going to remove the current deck, but plan to leave it as a sub floor. I have 3/4" plywood for the decks, but need some guidance about how to build the support for it without using too much wood (aluminum is not in the budget). Both the front and back decks are close to 4' square, and I'm guessing the height from the subfloor will be about 1' to 1 1/2'. The front deck will go to the console, and the back one will go to about where the seats would be.
Here's a pic, I can provide any other info needed. Thanks in advance for the help!
