Installment #2
Transom in and floor boards fitted. Boards are coated both sides with epoxy.
Boat is flipped and the sanding begins and never seems to end. There were a few rivets that were suspect. I tightened them with a hammer (both sides) and then touched them with some Gluv It sealer.
I sanded the whole thing with 220 grit (wet) paper and then cleaned ith with paint thinner. Any bare spots were primed with zinc chromate primer after a wash with a 50/50 solution of vinegar and water and the rest was just painted over.
Boat is painted (background) with Interlux Brightside using the roll/tip method.
Meanwhile the engine was gone through (new carb kits, impeller kit, plugs, rectifier, fuel pump, hoses, stat's and reliefs) and refinished with new decals, etc.
The engine had literally NO paint left on it. I painted any bare spots with zinc chromate after a 50/50 solution of vinegar/water washdown-just like the boat. The cowl was painted and the dark blue stripe is hand painted. Only the name and stripes are decals.
Under the hood, she was like brand new. This was a very low hour engine. It was bought new in 1983 and parked in 1984 and not to be run again until 2002.
I could run the engine, on that stand, (stand is on casters for easy movement) with a cut down plastic 55 gallon barrel.
The deck (flooring) is in with about 900,000 Stainless screws, each sealed with 3M 5200. The carpet is from Lowe's and glued down with exterior porch carpet glue.
The re-designed front and rear deck frames go in. You can see a livewell in the bow deck. You can also see the new front control center with: trim/tilt switch, trolling motor plug in, livewell switches (w/LED telltale) and timer.
A 15 gallon fuel tank went under the rear deck. I restored the aluminum tank by swishing BB's around in it for about an hour, cleaned it up beautifully. I also installed a fuel/water seperator under the deck with an access hatch. All the rear deck area was vented and a wall built between the battery and fuel tank. The battery had a Perko shut off switch.
