sheboyganjohn
- Aug 2, 2005
- 753
Re: Building a 23' Pacific Power Dory
I did not take any pictures of the glassing part. Doing most of the work by myself did not leave a lot of time to take pictures and not have the epoxy kick off on me.
So now that the boat has its layer of glass on it, It is time to install the external keil. I decided to cheat a slight bit. I made the scarf joint and did the glueup for it right on the boat. Here it is before adding the PB to it.
As I said earlier I ran a bolt through the inner keelson between the frames, except in the very bow since I could not get into the tight space in the front to get the nut on the back. Here I just used two lag bolts.
Once I had it bolted in place with PB between it and the hull it was time to start putting fillets along the edges to ease the transition for the glass. How do you like my handy dandy power duster. Much easier then trying to sweep off the sanding dust.
