Re: Bubbles, Blemishes, and Holes in first layer of fiberglass?!
Oh no! It was a lovely day here so I took the boat outside for some epoxy sanding. I used the tip to paint a light coat and sand until smooth and it worked great! The problem came just now when I noticed the front part of the boat had the epoxy turn a strange milky color. Like this:
When I ran water over it it turned back to normal:
When it dries it gets milky again...
I'm quite terrified. The temperature was 65 all day and it sat in the weak Missouri sun. Did this cause the epoxy to change colors? Would sanding it help? After all that work I'm finally ready to work on the inside and to have that part do that is really scary.
Any help is greatly appreciated!
For reference here is the boat before I started fiberglassing it:
To have that hand carved stained wood to turn milky on me now is so scary!
