Broken tab on retainer nut?!?
jasonachord
Only bad thing about DIY is in the process of fixing stuff you break other stuff :mad:
So I attempted to change out my bad u-joints with the method where you grind just enough off the corners on two of the ears of the retainer nut so the u-joint cap clears. It worked perfect except for the fact that i wasn't paying close enough attention to the center yoke between the two u-joints which was cocked to one side. As the u-joint pushed through the shaft the center yoke pushed into one of the retainer nut ears and snapped it off.
I understand the O-ring in the bell housing will not seal if I try to install the drive without repairing this. My questions are: :confused:
1. Can I simply purchase the proper wrench and new retainer nut, unscrew the broken one and install the new one at 200 ft lb torque?
2. Will I effect the upper drive bearings in anyway by removing and replacing this retainer nut?
3. should I just install the drive and go boating like it is? :)
Thanks
Bt Doctur
Re: Broken tab on retainer nut?!?
1 no, need to disassemble the input shaft , reset rolling torque
2 yes, need to reset rolling torque
3 personally no
dubs283
no
the rolling torque for the bearing pack is set before you install the assy and tourque the retainer
you will not need to disassemble the bearing/shaft assy to install a new retainer - just be sure to clean the outside thoroughly and re-install the shims
and remember, you set the torque on your wrench per the chart in the manual based on wrench length, not to 200 lb/ft
