broken panel mount fuse holder replacement
Dan Crenshaw
One of the panel mount glass fuse holders in my '83 Chris Craft has one of the tabs broken off. The problem is that they have 2 positive tabs instead of just one. the second one has a jumper wire to carry the power to the next fuse holder and so on. Now the 2 at the end dont work now because the power stops at the broken one.
All the replacements that I have found only have 1 positive tab and 1 negative tab.
Where can I find replacement fuse holders with 2 positive tabs and 1 negative tab, 3 total or am I going to have to replace all of them?
Dan
RickJ6956
Re: broken panel mount fuse holder replacement
You can buy a dual terminal adaptor. iBoats sells them.
Dan Crenshaw
Thanks. The fuse holders do not have 2 pos tabs. It is my jumper wires that are custom made and have female tab connectors that have male tabs coming out of them allowing the wires to be connected in a series.
Instead of trying to find one of them the dual terminal adapter will work and be much easier.
Again thanks.
