jumpjets
Thread starter- Joined
- Nov 11, 2010
- 313
I have a RINKER 262 CAPTIVA Cuddy with a 6.2L 320HP Merc and a bravo III 2.2 drive. It currently has a Merc bravo III factory 24P 3 blade counterrotating prop set on it, and the prop is way to small. The boat slams up on plane quickly, but it's top speed is low, and it's at 5700rpm WOT. It's supposed to be 4800-5200rpm WOT. The boat's minimum planning speed is at 3000rpm as well, which seems high. Right now the boat feels like an old chevy truck with 4.56 gears in it.
I'm going to upgrade to a 26p prop set, as that will get my WOT RPM into limits. I'm curious is anyone has any experience with some of the bravo III props available. Lower cruising RPM and top speed are important to me.
1. SOLAS 3 blade. Cheapest I've found, and available right here on iboats.
2. Mercury bravo III XR. Most expensive I've found, but I believe this prop is built for top speed.
3. Quicksilver Thunderbolt DPS. Marginally cheaper than the XR. I don't know much about it.
4. Hill Marine Four by 4. Great reviews, but it's a small company, and it's a counter-rotating 4 blade. That seems like it would have a ton of drag and sacrifice top speed.
Any recommendations?
