Bravo II will not trim down
Boating_Al
I just got the boat about two weeks ago, haven’t put in the water jet…today I noticed that drive will not trim down, when I hit the trim down switch I can hear the pump but the drive doesn’t move, fluid level is good. Could the drive be stuck in the trim/trailer-up position (I trailer the boat home), this boat sat on davits for over two years, so it never had to be trailer and the drive was never raised to trailer. Is there a way to trim drive manually…any ideals welcome….it’s a 1994 Bravo II<br /><br /><br />Thanks<br /><br />Al<br />Miami, Fl
Don S
Re: Bravo II will not trim down
Have someone run the trim down while you jump on the drive.<br />Many times people run the drive all the way up and lets the trim pump build up max pressure and just let it set. Then the valves in the pump have a tendency to get stuck.<br />Next time you put the drive up and it hits max up, just hit the down button to relieve the excess pressure. Drive may only go down 1/16" but the high pressure and stress on the system is gone.
Boating_Al
Yep, this sure sound like the same problem I’m having, I’m giving this a try tomorrow. Guys, thanks for your help…this forum is the best….Al
Boating_Al
Problem fixed, thanks again…..now I noticed that the trim-up doesn’t work but the trailer switch does. Been doing some reading/searching looks to be the trim limit switch, seems a quick fix is to bypass trim-up switch…where is the best place to tap into the wires to bypass the switch, which wires should I be looking for...thanks.
Look on the Inside of the transom,.... There'll be 2 pairs of Black wires,.......<br /><br />Somewhere along they're length, they'll join with the rest of the trim circuits with Bullet Connectors.......<br /><br />Just Switch the Connectors........... ;)
Boating_Al
Hey Bondo<br /><br />I switched the connector like you mentioned but it's all the same, trailer switch works but the trim will not trim-up. Is there another way to bypass the switch.<br /><br />Thanks
My Guess is you by-passed the Wrong 2,.... Or,....<br />There's a Break somewhere Else......
Don S
Not sure the reason for switching wires. One is a sender, the other is a switch and the operate on a different principal.<br />The trailer button doesn't go thru either one of them.<br />So instead of blindly switching wires, try some basic troubleshooting.<br />Here is a link to the Bravo OEM service manual.<br /> http://www.boatfix.com/merc/Servmanl/11/11covr5x.pdf <br /><br />Go to section 1C and there is complete details on how to test the system. Along with wiring diagrams.<br />Here is a direct link to section 1-C<br /> http://www.boatfix.com/merc/Servmanl/11/11c1r5x.pdf <br /><br />EDIT: Just re-read that you want to bypass the swic. Just locate the switch wires inside the boat disconnect the switch and connect the wires on the boat side together. Then the trim will work with the up button
Boating_Al
Got it, jumped the two wires, now both switches work trim & trailer….thanks guys.
