Brass Drain Plug... Please Advise :)
dmoss8928
Hey guys,
I got a quick question I just bought a 08 Q4 last weekend and I noticed to while I was cleaing there is a brass plug right beside the regular drain plug. Its on there extremly tight so I didn't force it off. Can anyone tell me whats it for and if i need to keep it off while I store the boat?
Thanks for the help....
I post on the tahoe forum and no one repled :(
dmoss8928
Re: Brass Drain Plug... Please Advise :)
Here is a couple of pics... thanks for the help
UncleWillie
From the Pix it could be anything.
The obvious question is, What is on the inside of the plug?
Is it just a hole in the transom, or is there a hose connected to it going to somewhere?
zopperman
looks like a garboard drain to me...
NYBo
Yep, that's a standard garboard plug and fitting. The question remains as to just what it drains. It's too high to be for the bilge (which uses the other drain in the one picture).
dmoss8928
Im not to sure if I even know what a Garboard Drian is for? :( very new to boating haha
UncleWillie
Technically, a "Garboard Drain" would be the drain next to the Garboard.
The Garboard (Old Dutch word) is the first hull plank next to the keel on a wooden ship.
Today, the Garboard drain refers to the bilge drain at the bottom center of the transom.
Technically, your Garboard Drain is the Black Plastic drain to the lower right of the brass fitting in the photo.
The Brass fitting that you have is normally sold for use as a Garboard Drain .... But not in this case.
In this case it is just a plugged, fancy Thru Hull Fitting.
All of this is interesting but does not answer the original question, "What is the Brass Fitting for? "
That takes us back to the other un-answered question posed to you ...
"What is on the inside of the Brass Fitting, A hole? A hose to somewhere? WHAT???" :confused:
Answer that question and you will answer the first question. :)
dmoss8928
I have tried to see if there is a hose or anything attached to it, and I am not able to fully get back there. So i'm just not going to worry about haha...
smokeonthewater
take the plug out.... pour water into any compartment you think might drain through it.... when you see water you have found it.... My bet is you have a compartment that doubles as a built in cooler
dmoss8928
I would but someone said it was a drain for my motor oil, so I don't want oil pouring out. I thought about trying that tho....
smokeonthewater
well if it IS for draining oil there will be a hose from it to the oil pan and there BETTER be a valve at the pan AND finally, if it were my boat and it WAS for oil, I'd be getting rid of it.
either way, loosen it up and see if oil starts to seep out (I doubt it) or if you find water or air behind it
bellhop
It is a drain for the engine oil. Loosen the plug, it's attatched to a tether that's attatced to a drain line. Take the cap off the end of the drain line and the engine oil comes out. (Done outside of the boat of course)
dmoss8928
smokeonthewater... Why would you get rid of it if its for oil?
bellhop... how sure or you its for oil? and is there any reason why I would need to take the plug out?
sschefer
It for a stern shower. You just didn't get the rest of the option.
smokeonthewater
because the ONLY thing I want screwed into the bottom of my oil pan is a plug.... I want it tight and NOT leaking... I don't want any valve that could fail or be opened or a hose that could fail. Further IMHO the ONLY good way to change oil in a boat is by pumping it out through the dipstick.
BlkY2k
So your sure its for a shower? if so where does it drain from?
Hmmmm
haulnazz15
^This. Open it up and find out. Even if it is oil, loosing a teaspoon of oil isn't going to matter.
