Bow Thruster
GT1000000
Re: Bow Thruster
For somebody that doesn't know what they are doing, you are making this look easy! Very nice, can't wait to see it finished up and to find out how well it works for him...
ahmincha
Re: Bow Thruster
This boat has bottom anti fouling paint on it would that be enough over the repair Thanks
shaw520
Re: Bow Thruster
Nice Job!!! ...You dont mess around sir!
Up to what size boat is a 7" thruster rated for ?
ahmincha
Re: Bow Thruster
Thanks shaw I am not sure what it is rated for. I do know its way to big for a 27
Woodonglass
Honorary Supreme Mariner
Re: Bow Thruster
I've been lurking in the shadows, watching you put holes in the bow of this boat!!!!:eek: I've been wondering what the outcome was going to look like and if you would be able to pull it off, especially with the strake being located in the middle of the thruster hole etc.. If I had a Glass shop and you were applying for a job and you brought the picture from post #26 into my shop as a sample of your work... I'd hire you on the spot!!!! Well Done!!!!!
ahmincha
Re: Bow Thruster
Thanks wood I appreciate that. I had asked if antifouling paint over the outside peanut butter would be sufficient But never got a answer . if anyone knows the answer I would appreciate it. It has a small leak coming into the area about 4 oz in 2 hours so I am going to start grinding where it seems to be coming in just to make sure
Woodonglass
Re: Bow Thruster
You ground off all the AF paint and applied pb and glass to the repaired area and then recoated with AF paint correct? If it's leaking it's NOT because of the Paint. There has to be a void in the glass repepair some place. You can some times use some red water based paint in the water and see where its coming in.
ahmincha
Re: Bow Thruster
I ground to the original glass then repaired yes ok just wanted to make sure it wasn't a easy fix haha. I ran out of time today to ck real well but its either a void in the glass or the gasket around the thruster itself. will update tomorrow thank you
zool
Re: Bow Thruster
Well done!...you can leave the raw glass, but you should use a barrier coat made for your antifoul paint regardless whether u used epoxy or poly. But like Woddy said, its not ur leak problem. Once its launched, your prolly experiencing stress from the rigid tube to the flex hull...keep filling and working it, it will become solid.
If u used poly, you can mix some gel past, and skim the area, sand it smooth, then apply the barrier coat and paint, if epoxy, just the barrier coat, and paint...if you used interlux, interprotect would be wise, most epoxy primers will seal it too..
ahmincha
Re: Bow Thruster
Thanks zool gel paste? yes I used poly Thats my plan sand it down and see what i can see
ahmincha
Re: Bow Thruster
Well I went and took a look and it seems it might be the thruster gasket leaking. It only seems to leak when thruster is used We are going to pull boat out of the water tomorrow or fri will update
