Bow Safety Chain
cbavier
Do you use a safety chain or aparatus to secure your boat beside the winch strap or winch cable?
bowman316
Re: Bow Safety Chain
put a poll on here.
would be an interesting poll
boat1010
Personally I don't have anything else but the winch strap. BUT I can see the advantage. I have broken the strap while winching the boat tight, so know that they can break. So Am not sure why you are asking the question but if you are looking for more safety it is a good thing to have.
nlain
My trailer came with a chain and wench strap.
txmntman
Yes, absolutely! There are many things that can happen and all of them are bad. Your winch could lose it's lock and the boat can be pushed back down the trailer. If you don't have your transom straps down tight, then your boat could bounce and hurt your boat, but if you don't have your BOWEYE securely tied down, your boat could come off the trailer and kill someone behind you.
In short, always add a second tie down method to the bow eye. I have used a rope for small boats, a web strap, and a chain. Different people use different things, but please, please use something. It is cheap insurance and a step up in safety.
BWR1953
Agreed!
I use a bow tie-down strap. It's cheap insurance.
ziggy
yep, i have a winch strap + a safety chain too. i wouldn't be w/o. i have a roller trailer. going down a ramp, if it were free, it'd just roll right off. i want two ways of holding it in place..
even when i had only had a waverunner on a bunk trailer i used 2. the winch strap + a extra line tied on tight to the boat and trailer too. though that one, i'd release the extra line prior to dipping her in the water. the boat on a roller trailer, i leave both connected till it's in the drink. them roller trailers really roll easy..
bhammer
Ensign
I use the bow safety chain and I have two stern straps. I have seen two times where a driver failed to stop and hit a pole, and a car in the other case, and the boat climbed the trailer and ended up partially on the car.
In another case, I saw a bass boat stern bouncing up and down as we traveled 60 down a semi bumpy road.
Secure your load!
idrownworms
So the wench can strap you when you do something wrong?
inquiring minds want to know
but seriously folks I use the winch strap and chain on the bow and I have the stern strapped down ( well usually the ramp I use mostly is a quarter mile down the road and it's idle speed all the way anything longer and the stern straps go on )
jamie
Chiliando
I also use a chain and stern straps. Just in case.........
Campylobacter
I use a chain, but it has an "S" hook on the end, and it does not inspire a lot of confidence that it would stay on in an emergency.
cpubud
wench strap, safty chainand, 2 transom straps
cbavier
Jamie I wouldn't leave the ramp without my stern straps. One bump and you chance loosing the boat. It's just not worth the extra two min it takes to put the stern straps on.
vintage boat junky
Yes, chain! I think it might be law in some places. However, I have snapped the bow eye while cranking the boat up, rendering both winch and safety chain useless. So, perhaps a second bow eye could be beneficial as well.
cbavier
I've never heard of anyone snapping a Bow Eye Bolt but I suppose anything is possible.
