FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
I Have a 1986 force 125 hp. outboard I would like to know how to remove the flywheel with the tools of a backyard mechanic..i have all the tools needed just laking the know how.any help greatly appreciated. thanks BVC.
OK. The suggested puller is a must. As the flywheel most certainly won't come of by hand, trying to rmove it without a puller ain't smart.<br /><br />The puller uses the crank end to push against while pulling the flywheel. So remove the big nut & washers and attach the puller. Make a mark of the exact fit (crank and flywheel). Turn the puller bolt to pull the flywheel off. This can be a matter of applying a lot of power so use good tools.<br /><br /> See Merc's version here
