Bow damage fix?
MotorMan101
My boat has some bow damage and if I should just add some new fiberglass resin to it and a couple coats of fiberglass... Or is there something better I could use?
tpenfield
Probably some glass mat in the keel area . . . sand it smooth . . . and then gelcoat in the larger area around the keel where there are deep scratches.
Looks like keel/bow damage from beaching. There are keel gaurds that you can buy to protect the hull, if you frequently beach the boat.
todhunter
Canoeist
I had similar damage. I mixed up some PB to fill the deep gouges, then rolled on a few coats of white gelcoat over that. If you are going to do a keel shield (recommended) you won't have to worry too much about the cosmetics, as the keel shield should cover most of that.
CapriBX
Enjoy the journey and learn a new skill.
KJM
Yeah, I had similar damage on mine and used PB, sanded and gelcoat.
MotorMan101
Kinda silly question but what is PB?...I like the keel guard idea although I have never beached it damage from previous owners...
MotorMan101
I have a bow rider that has basically no access under the floors. I have only had it out three times about a hr each time and once for two hours. ..after each trip water is built up in the bilge about ten gallons at least over two hour trip...I can't find where the water is coming from...I do have some bow damage and am learning to fix in a different post...but my question is how do I confirm leak location...on my jon boat I filled boat with water...but on this that seams a bad idea ...
CapriBX
I’m going to assume the water is coming in through the holes in your boat…..
You have holes showing in this picture where the boat was beached
Fix the damaged keel
Never fill a boat with water
Woodonglass
PB is polyester resin mixed with filler to the consistency of creamy peanut butter… thus PB!
JASinIL2006
Ten gallons of water over two hours is a LOT of water getting into the boat. To me, that suggests that either you're getting intrusion from other places or the damage to the keel is even worse than it looks in in the pictures. If you're getting that amount of water inside the boat, I'd also be very concerned about stuff that you don't want to get and remain wet, like flotation foam, stringers and transom.
Is this an I/O? An outboard? I'd be checking to see you have water intrusion from other sources. The keel has to be repaired, but I'd be looking for other sources of water intrusion, too.
  • Like
Reactions: KJM
