Bottom Paint
rmgmag
This is my 2nd year of boating and it looks like I'm due to put a new coat of bottom paint on my boat. We primarily dock it on the river (freshwater).
It's a 21' Four Winns Sundowner with an 8 1/2' beam. How much paint am I going to need (that stuff is freaky expensive)?
Any brand recommendations would be appreciated too.
Thanks,
Bob
chriscraft254
Re: Bottom Paint
Can't really help you with your area. It might be good to call a local marina that deals with your area all the time and see what they use for the rivers you run in. Each area and body of water can call for different bottom paint. It may also depend on what is compatable with your existing bottom paint. It may need to be removed and prepped first. Good luck.
Re: Bottom Paint
You will need about 2 qts. It could be a bit more or less, likely less, but buy a gallon, and save it for the next time. Here in the salt pond I use an ablative paint, because I can get 2 years out of a coating. I would think you could do the same, but asking around is a real good idea, to verify.
Downforce6
Re: Bottom Paint
Thanks,
Bob
Did this last weekend... My boat is quite a bit smaller. a 17'er, I forget the beam but thinking 7.6'
I used not quite a half gallon, I put it on fairly thick with a roller.
A gallon should do you I think. I won't make any brand recommendations as I've only tried one.
JoLin
Re: Bottom Paint
Ditto that. My old 24' express took no more than 3 quarts. If you're gonna buy a gallon make sure the leftover is really well sealed and kept in a cool place.
rmgmag
Re: Bottom Paint
My guy at the marina told me that because we were in fresh water that we didn't need bottom paint. He said he'd love to sell me $200 worth of paint, but it just doesn't need it unless I'm planning on spending more than a couple of weeks at a time in salt water (which I'm not). So I guess I dodged that bullet, for now. Thanks guys.
TilliamWe
Banned
Re: Bottom Paint
If you keep your boat in the water all season, you need an epoxy barrier coat, then bottom paint. The barrier coat prevents blisters from forming, the bottom paint keeps the growth off (or down to a bare minimum). It has nothing to due with salt or fresh water. That guy doesn't quite understand bottom paint, then.
