FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
I don't know the ocean pro but seems to me the problem is with the carbs - - the needle in the float bowl is not seating therefore not stopping gas from entering.
Easy enough to check the pump. Pull the pulse hose off the pump and squeeze the bulb up. If your pump diaphram is bad then gas will come out of the pulse hose nipple of the pump.
Also may want to check the red (manual)lever of the fuel primer solenoid in the engine compartment and insure that it is closed and seated all the way in the clockwise direction.
