bondo skim coat?
charkbait
I have significant gouging and dings in the hull of my 17' whaler. I patched with evercoat but think a skim coat of some sort really go a long way in helping my process. To do it with evercoat would cost about $60 and I can do it with bondo for $22 or so, any reason not to?
I plan to barrier coat the boat with epoxy before painting.
jcsercsa
Re: bondo skim coat?
Not water proof !! I say dont do it !! it well blister and come off !! John
drewpster
Bondo body filler is not intended for use on boats. The filler material used in Bondo soaks water. If you are barrier coating with epoxy I suggest you use an epoxy filler. Using non-marine products even under the barrier coat is too much of a risk in my book. After all that work it would be a real bummer to run into problems with it down the road.
