bolt on fender support and leaf spring mounting shackles attached
sprintst
Just checking to see who sells these bolt on brackets that have the leaf spring shackles attached. They slip over the frame, bolt on and then have the fenders welded to them. Nothing is welded to the frame which makes it easy to swap out...if I can find them.
I`ll see if I can dig up a better picture as you can barely make them out in this pic.
Re: bolt on fender support and leaf spring mounting shackles attached
Ayuh,... You may have a trailer manufacturer specfic part there....
What brand is it,..??
sprintst
Snowco - Snow Company Might be an issue finding parts since they got sold off a while back.
I may just buy brackets like I found and have the shackles welded on.
