Boats from work.
MikeSchinlaub
Master Chief Petty Officer
I don't know what happened to this one, but this trailer doesn't have guide bars so can't be that.
Cobalts look nice but they seem to be getting harder to work on. More stuff that was only meant to be accessed while the cap was lifted for assembly, so harder to reach or just have to cut a way in. Like this thru hull, no way to take it out without making a hole, sealed up with 5200 even though it's well above the water.
The colors are also nice until you have to work on them. Grey will almost never blend when you spray gel. Even a new boat with factory color from spectrum will stand out. You have to paint it, and they're hard to match. Sometimes the clear also stands out, so you have to go big to hide the blends.
MikeSchinlaub
I finished the Crestliner yesterday. Looks like I forgot to take a picture though. The only difference is a rubber diamond tread pad on the starboard side of the nose.
redneck joe
tread plate for traction? Not much better than plain
this is what have on mine. Will be adding to the trailer fenders as well.
MikeSchinlaub
The plate is reinforcment for the trolling motor. It had enough torque that it cracked the surface. There is actually a reinforcement plate welded underneath from the factory, and it cracked on one of the welds.
MikeSchinlaub
The truck left this morning. The cab is very nice inside. Should've got a picture of the truck outside, but I didn't.
Then I spent about half the day cleaning some stuff up, waiting on my next job to show up. A regal that someone else had tried to do a spot in but couldn't get the color.
aspeck
That color on the Regal doesn't match ... don't you love fixing up someone else's mistakes?
