Boating 101+6½ - ANSWER
18rabbit
A vessel may display the international code “A” (alpha) flag in one of two scenarios. In one scenario the vessel is never at anchor; in the other scenario it usually is.<br /><br />
<br /><br />What are the two activities a vessel may be engaged in that would be an appropriated display of the alpha flag?
18rabbit
Re: Boating 101+6½ - ANSWER
Diving…humm…sounds like the scenario where the vessel is usually at anchor. :) <br /><br />What about the scenario when the vessel is NOT at anchor? You may presume the vessel to be moving slowly or zipping across the water like greased lightening.
LubeDude
There are two types of diver down flags and both are appropriate to display. They are a red flag with a white diagonal stripe and a rigid replica of an "alfa"
SpinnerBait_Nut
Originally posted by LubeDude:<br />There are two types of diver down flags and both are appropriate to display. They are a red flag with a white diagonal stripe and a rigid replica of an "alfa"
Hey LD, we know that, but what about the question though?
Drowned Rat
The technical reason you are supposed to display the Alpha Flag is to let others know you are restricted in your ability to maneuver because you are engaged in diving operations. If for some reason you are not restricted in your ability to maneuver, the flag would not be appropriate. 18Rabbit, is this the other reason? Can't figure this one out.
SpinnerBait_Nut
The only other reason I can think of is that it is being towed behind a boat.
tylerin
ALPHA FLAG<br />Vessel has personnel and/or equipment in waterand is unable to maneuver. Do not approach; maintain a safe distance of at least 100 feet around vessel. Watch for divers. <br /><br />Vessels displaying these signal flags could be moored, anchored, drifting, or slowing towing divers.<br /><br />
Drowned Rat
Reason #1. Diver or equipment in the water, restricted in ability to maneuver.<br /><br />Reason #2. Restricted in ability to maneuver for any reason. The flag is appropriate to fly for this reason regardless of the presents of divers or not.<br /><br />The true reason for flying the flag is reason #2. It's just tradition to show it while engaged in diving activities and most people recognize it as such.
18rabbit
ANSWER – Scenario 1 <br /><br />Vessels that are restricted in their ability to move due to underwater operations, including diving, are required to display the navigation lighting and day shapes as described in Rule 27d. (Basically, 3 vertical all-around mast lights in a red/white/red configuration and 3 vertical day shapes in a ball/diamond/ball configuration.) This vessel has stand-on priority. When the vessel size is small enough to make the display of lights and shapes impractical, an alpha flag must be displayed; Rule 27e. In other words, smaller recreational boats used as diving platforms typically fit the requirement of displaying the alpha flag.<br /><br />Ironically, both the International and Inland rules state that if the lights and shapes cannot be displayed, then the lights and an alpha flag must be displayed. The alpha flag is a substitute for the day shapes, but not the required 3 vertical all around lights.<br /><br />
<br /><br />The “diver down” flag, red with a single diagonal white strip, is NOT a substitute for the required lights, day shapes, or alpha flag. In the late-80’s/early-90’s the new proprietors of a small recreational dive shop on the east coast prevailed in a civil suit to establish trademark recognition of the diver down flag. As plaintiffs they were able to prove the little shop they bought was the originator of the diver down flag nearly 50-years prior and in purchasing the shop they also purchased the flag design as an asset. The court agreed. They don’t stand a chance of ever enforcing trademark protection. I question the appropriateness of any local rules (Florida, Mississippi, parts of So. California, others) that require the diver down flag to be displayed during diving since it is trademarked protected.<br /><br />Any requirement for a skier down flag is a local rule and they vary from one locale to another. In some states it’s a red flag; in others it’s an orange flag; in some it’s either red or orange. There may be other colors required.<br /><br />ANSWER – Scenario 2 <br /><br />A vessel engaged in a speed trial may display the alpha flag. This vessel does not have stand-on priority. As a courtesy, you may wish to pilot your vessel in such a manor to allow this vessel to proceed on a steady course and speed with priority.<br /><br />Diving is a fairly new technology when compared to seamanship. The international code flags existed and had meanings long before anyone when underwater. I have not yet be been able to locate the authority for this, but I suspect this other meaning of the alpha flag has its origin in a time long past and the contemporary meaning is probably the result of the adoption of the 72 COLREGS in 1972. References for the use of the alpha flag during vessel speed tests can be found in older publications about the international code flags. There are also web sites with details about the use of international code flags that also mention the use of an alpha flag in this way.
Drowned Rat
18Rabbit, where does the speed trial reg. come from? Never heard of it. Interesting. :)
18rabbit
DR - I haven't taken the time to chase it all down, but in 1972 the International Regulations for Preventing Collisions at Sea (72 COLREGS) was adopted. They are the International Navigation Rules we all know and love. The use of the alpha flag for diving was starting to be standardized in 1969, just 3-years earlier. I suspect it took those 3-years to get everyone to agree on the COLREGS.<br /><br />Here is a web site with a brief explanation of some of the meanings; past and present.<br /><br /> http://flagspot.net/flags/flagicsa.html
