boat
ringo111
hi .guys anybody have any advice for this problem .i am trying to bring back color in fibreglass boat i have used 3m boat restorer.it looks goos for about a minute then haze reappears back in gel coat how can i keep this out from appearing
GA_Boater
Ringo - A suggestion for you. Put some info in your topic title, like "Boat - Hazy Gelcoat". This topic was almost deleted as a duplicate because you used "Boat" as the title for multiple topics. It also helps other members help you.
Woodonglass
Honorary Supreme Mariner
You'll prolly get lots of remedies but...the bottom line low down to restore gelcoat is to wet sand it starting with 400 grit and got to 1000 then buff with compound and finish off with polish. There are a LOT of temporary remedies including Vaseline, Transmission Fluid and many others. They all work for a while. Even the wet sanding requires you to do yearly updates with the polish and buffing. That's the nature of Gelcoat. It all depends on what you want to do. Check this out...http://forums.iboats.com/forum/boat...anding-and-buffing-on-my-gelcoat-this-weekend
