Boat prop question
codymeggs
What is the best size prop for my 1983 90 hp Johnson model j90tlcte motor I have a 9x13 on there now?
hidef
Re: Boat prop question
Do you have a Tach? Ideally you want the engine to turn around 5500 RPM at WOT with your normal load. Not knowing the size, type and weight of the boat makes it hard to determine what size prop you should be using.
boobie
You'll have to run it with a good known tach on it and then prop it out to the correct WOT range of the mtr.
steelespike
A 13" prop sounds like maybe a pontoon or a brute of a boat.?
If you read "read this first" at the top of the page it will help you get us the info we need.
