Moparmadness316
- May 2, 2016
- 15
I am going to replace the deck on an 18 foot 1984 Sea Raider bow rider. I see so many different discussions about replacing the deck. I removed carpet because you can feel soft spots in the floor. What I found under there is horrible. I have seen this stuff in Lowe's. I think its used on walls in a house. I think it is called OSB. I don't think that this has any place being on a boat. But the question is.... what is the best thing to use to replace it? Plywood? MDF? What is the best finish to use after? I have seen posts that range from Poly resin, to epoxy resin to just paint. I am going to put a marine grade carpet back down. Advice please...
