- Oct 25, 2011
- 25,265
Expensive and heavy compared to plywood amd not strong enough for use on a transom.
The problem, IMO, isnt the wood or flotation foam used in a boat, nor is water the enemy. Poor quality control or lack of attention to detail during construction arent the problem either.
Basically, IMO, the vast majority of problems associated w rotten decks, stringers and transoms could have been avoided if previous owners did better maintenance and stored the boat properly.
All that ^^^ is why I recommend using the best plywood you can reasonably get, be diligent w surface prep and the glass work, use adequate flotation, then keep the boat stored properly when not in use : Bow up, well covered w the drain plug out.
The Lowes link you provided is $37 per 8ft 1X8 pvc plank. You'd need 6 to replace 1 4X8 sheet of plywood. I could get 2 sheets of highend 4X8 3/4in marine plywood for that.
