Blown Cylinders???
Dobb15
I am helping a Friend with is 79 searay and it has a 4 cylinder in it ... i compression tested the cylinders cold and the front has 125 the back 90 and zero in the middle 2 ??? could this be a bad head gasket??
Don S
Re: Blown Cylinders???
It could be, but with 0 psi, I would expect possible head or block errosion to go with a bad gasket.
Was the engine running ok, then just quit, or is this a rebuild not working?
