Block repair 80 AETO 1983
Needles
I need to repair the block .
I am hoping to use HTC 2000 .
The block is warn on the outside of the water way in 2 areas on the side that the cylinder head attaches to.
and a small 2ml deep grove on the exhaust side of the block,this is going from the exhaust to water way.Would a
filler do the job on this or use HTC 2000 here also?
I have removed the power head from the upper leg of the outboard and was wonder if there is anything else worth
doing since its removed and mostly stripped down.
regards
