dmball
Thread starter- Joined
- Jun 6, 2010
- 33
So I went out on the boat today to enjoy the holiday weekend. First problem after the launch was the engine would not crank. So I jumped the starter solinoid and it would start up. So no big problem just had to use a screwdriver every time I wanted to start it.
Ran it most of the day and ran like a top. So I beached the boat next to my parents house boat and ate lunch. Then decided to go out and pull my sis and her boyfriend on the tube. So I start pulling them around and it was having a little trouble pulling them. Then it slowly died while cruising like it lost fuel. So it drove back to the park but had little power. I could get it to restart after that but it would die if you tried anything but idling it out of neutral.
So I put it on the trailer and got home. Checked fuel pump screen. Checked to see if fuel was "pulsing" but I could not tell if the flow was good enough or not. So next I pulled out the spark plugs. #1,#2 look dirty but ok. #3 had a gray paste on it(fried rings??). I dont have a compression tester at home so i put my finger over the hole and #3 has nothing.
So does anyone have experence rebuilding these? I know I will have to disassemble to inspect the engine block. Hopefully the block isnt too messed up so I can hone out the cylinders and still run standard pistons. Anybody know were to even get oversized pistons if I do need to get the block bored? And any other advice? Should I even rebuild it or say F*#@ the sport jets forever and have a boat burning party????
