Bleeding Oil Injection Yamaha 60tlrc
Perspective
BLUF: How do I bleed the oil injection system on my Yamaha 60tlrc 2 stroke?
I was planning to go fishing and was topping off my oil injection system. I grabbed the Yamalube and started to pour when I realized it was the gear case oil so much heavier. It wasn’t much but I thought it best to dump the oil reservoir. I did this by pulling the oil lever sensor and dumping. Also disconnected a hose from the bottom and let it drain. Got most of the oil out. Figure any residue won’t hurt anything.
This ended up being a good thing as I discovered the throttle linkage clip was split. Temporarily used a zip tie to hold it together and put everything back together.
The engine will crank but won’t fire. Is there a reason something that could cause this? Flooding maybe?
During the troubleshooting I realized I need to bleed the system, my service manual says to do this but doesn’t provide instructions on how? Online tutorials say there is a screw but my oil injection pump doesn’t have a bleed screw on the side. There are two screws on top for the bracket that the return hose is connected to. Do I just unhook the return hose. Google AI says to disconnect the linkage, run the engine off a reserve tank, and max out the oil pump. Unfortunately, the links they provide don’t reflect that direction. Is this correct for a pump with no bleeder screws.
Any help would be greatly appreciated.
Perspective
Yes, I’ve seen that video but my pump doesn’t have a bleed screw. That one is older than mine. Plus my oil tank blocks access to the pump so I’m guessing bleeding might be accomplished some other way.
99yam40
did anything say to mix up some 50 to1 gas and run the motor on that.?
mark the oil level in the oil tank to make sure it goes down so you know it is pumping.
you should notice when it has double oil from the smoking
boscoe99
The oil system does not need to be bled if all you did was remove and reinstall the oil tank. There will be oil in the line from the tank to the oil pump. Once you refill the tank any air that is in the oil line will vent itself into the oil tank.
Perspective
The service manual only says to bleed but doesn’t explain the process. I do plan to run on a separate tank with 50:1, so maybe that’s all I got to do. Not sure why it won’t fire, thinking I flooded it or something.
Perspective
Well, the hose on the bottom of the tank that feeds to the pump did come off. But I’m thinking that bleeding for this engine may mean to just run the motor on an external pre-mix and let the air run back through from the return line. Thank you.
99yam40
did you check for spark?
compression, spark and spark timing are the easy things to test , if all of those are good the it would be the fuel to air ratio ,but that is not as easy to check
boscoe99
The hose from the tank to the oil pump is self bleeding. Bleeding is to purge air in the hoses from the pump to the carburetors.
Perspective
Gotcha, so would assume that running the motor with a separate 50:1 tank would bleed the system or should I pull each of the hoses to the carb similar to the procedure used to test oil output.
Perspective
Thanks for the help everyone.
So, I set the oil injection according to the service manual (1mm from wide open) but had to eye it as there is no way to really measure it. The starting issue was flooding but it cleared quickly this time. Last time it was severely flooded. I currently have it idling around 1500 rpm to see if it uses any oil. It’s running like it has more oil. This is the only way I can see bleeding the lines safely. There is no way to pull any oil lines from the carb as they are buried under the oil tank.
Perspective
I did figure out how to check the output of the top cylinder and it was within book parameters so I am now confident in running it on the driver again. Ran smooth as butter on the unmixed. Yamaha’s oil injection system is fascinating.
Mc Tool
Yeah they certainly seem reliable ....their 2 stroke motorbike pumps were good too ....I assume they operate similarly 🙂
