Bimini Top
lcecere
When you are trailering your boat do you keep your bimini top up or put it down?
fishrdan
Re: Bimini Top
Down, bimini's are not designed to handle freeway speeds.
Many suggest removing the bimini so it doesn't get blown off the boat while towing. I sewed a couple 2" wide Velcro strips into my bimini cover, so I can secure it to the rear cleats while towing.
Home Cookin'
Re: Bimini Top
although they are supposedly rated for speeds around 50 mph it's not a good idea to test them--why put them through the wear and tear plus the risk of coming loose and causing a wreck? You are unnecesarily stressing your fittings.
Short haul low speed with no trees, no problem--whatever is most convenient.
Lake Lizzard
Re: Bimini Top
Keep it down and secured for a few reasons:
  • They are not designed for freeway speeds
  • You don't want to have to buy another one if you damage it in transport
  • You don't want to damage your boat
  • You don't want it to fly off your boat in transport possibly injuring someone, killing someone, or causing an accident.
Safety first. Just plan a few extra minutes an the lake to set it up and put it down.
bruceb58
Re: Bimini Top
Don't even drive with it folded up and stowed in its boot. I lost one of mine that way.
greekfreek
Re: Bimini Top
Tow with mine down, use a velcro strap to keep supports together, use cut piece of life vest as a "biminibumper" keeps the tubing from hitting the boat. Poor design..
Re: Bimini Top
short distance and low speed (3 mile trip at 45mph) - I left mine upright folded in its boot
longer trips - folded down laying on the cover, strapped to the boat
moving - removed from the boat, wrapped to not abrade, stored under the cover
pipe insulation works well to keep the supports from banging into each other or wearing on other things.
MH Hawker
Re: Bimini Top
Mine is up and in the boot but its a 20 mile trip once or twice a year to the marina and under 60.
Husker-Q
Re: Bimini Top
I always lay it down while trailering . The way mine collapses, I have to bungee the brace on each side to the rear cleat.
bruceb58
Re: Bimini Top
I lost mine when the fitting that attaches to the boat cracked. I was going 35 MPH when mine broke and I never found the cover.
MH Hawker
Re: Bimini Top
Well mine is a cheep one and if it dose it may be a excuse to get a better one. :D
