Bimini top question...
parallon
Hello all. I have a 2007 Suncruiser BT210. I would like to add a second bimini top (front) and was wondering if it is the same top at the one in the rear, or are the front ones different. I was just wondering because of the placement of the side door, and want to make sure that the brackets don't end up in that position.
Thanks,
Mike
a1nowell
Re: Bimini top question...
I used the same style for my bimini on the front of my 24' tritoon. I just positioned it so it woud not interfere with the side gate.
Try these guys out. They are a manufacture that sells direct and can make almost anything in the bimini world you want at very low prices.
http://northstarproductsinc.com/
parallon
Right on. Thank you. I will check this out...
Mike
vergil
it depends on what style you have on the back. i for example have a buggy style in the back and that would look kinda goofy if i put the same style on the front, I have been thinking about a front bimini top, i think i will go with a small one so it doest get in the way as bad
when fishing
wedge542
i had same deal,gate on both sides halfway,went with two tops,works great.
