Re: Bimini Top Material
Sunbrella is the most famous, and the most expensive.
The UV rays from the Sun are the killer.
If you slip the boat and it is going to see a lot of weather, Sunbrella's 5-7 year lifespan may mean something.
If you trailer and take it down and keep it covered between outings, even the least expensive will last for many, many years.
Depending on the height and size, a Bimini may be rated for 25mph for a Larger/Taller one, to 45+ mph for a Shorter/Smaller one.
Most will easily withstand tubing, wakeboarding and skiing speeds.
Going wide open in a go-fast? Place it in the Storage Position.
Even if it will take it, you won't like the extra Lift and Drag that the 6 foot Wing/Parachute will add.
