Re: Bilge Pump Questions!
Follow the directions! But if you have no instructions, a bilge pump does you no good unless it is installed in the lowest point in the bilge. Connect the hose to the pump, route it up to a point on the side of the boat well above the water line to a through-hull fitting or over the stern. Connect the wires to ground and the switch and you are all set.
