Help Please! I have a 2003 regal 1800 and not realizing I had a automatic pump I turned on the switch at the helm while we were out. The light on the switch went out so I check the fuse under the helm and it was blown. I replace it and flipped the switch, it blew right away. I replace it with a larger fuse and flipped the switch, fuse held but the pump would not go on. I cant see the pump anywhere. I followed the hose from the outlet to behind the motor then I lose it with all the blower tube and exhaust and drive. My manual says it should be under the front of the motor. I remove my back seat and reach as far as I could under the motor and nothing. HELP!
