JimS123
- Jul 27, 2007
- 8,361
Re: Bilge Area Water Level
As others have said, zero water is the only acceptable amount. My drain plug hasn't been out in 28 years because I never had a drop of water to drain.
This isn't rocket science. A leak in a dry boat shouldn't take more than a minute or 2 to find, unless its in a totally inaccessible area.
Run the engine on the muffs for 15 minutes. If no water, its not the engine.
Put it in the water with the engine off. Raise the outdrive full up for a few minutes, then full down. I'll bet that test will show a bad bellows.
Whatever you do, pay close attention to the lowest part of the bilge, under the engine where the bilge pump is. Look for any rubber corks or plugs that vent the hull under the deck. If water comes out from there you have a crack in the hull that's not in the open bilge area. If your transom drain plug leaks it will be quite visible. If you can't see well enough into the WHOLE bilge, buy a mechanic's mirror with a telescopic handle.
