Bilge and aerator problem
usmc42000
Hey guys. I've got a 99 Legacy center console. I went fishing wednesday and noticed that my bilge pump and aerator for my live well are not working. I also had a problem with my tilt/trim going up intermittenlty but I found a bad relay was the source of that problem. I haven't dug into the bilge and aerator problem yet. I was just wanting a little advice before I jumped into it. The bilge and aerator each have their own toggle switch on the console. I'm planning on checking the fuses first and then going on from there. Is it possible that the bilge and the aerator both use the same fuse? I was thinking that whatever the problem is would be common to both the aerator and the bilge because it seems a little odd for both to go out at the same time. Thanks for any advice.
bankerjohn
Re: Bilge and aerator problem
The could, but they should each have their own separate fuse or breaker!
