honda_man_300ex
- May 16, 2012
- 18
HI guys. i have a 97 e40reuc. I just recently installed a set of chris carson reeds, and rebuilt 50 hp carbs. the motor runs but after it's warm i'm getting a sneeze back through the intake at idle and it will only open up to full throttle if i press the primmer switch while at full throttle. also if you give it fuel too fast it stalls. The carbs are clean and i took my fuel pump apart and replaced some rotten orings and blew out my fuel lines. The carbs have the stock 50 hp jets but i can't help but wonder if i need bigger ones because it runs good if you press the primer. and runs fine at half throttle. could bad fuel cause this? i would think bad fuel would be more issues. if i do need bigger jets how much bigger should i start at? just one size at a time? both high speed and the intermediate or just high speed? thanks for any help.
Craig Foster
Craig Foster
