Big Twin Aquasonic 25
Pitcherofnectar
Hello forum,
I picked up this "garage kept" 1955 Evinrude 25 this weekend. it was stored drained and with the plugs out about 30 years ago. Mice at some point took residence under the power head. the combo of open cylinders and mammal farts over decades made the Pistons stick pretty bad, though I was able to get them moving surprisingly easily with a bit of marvel oil. Everything turns really great now, never felt like I was powering through anything or like any damage occurred.
The is my first attempt at an outboard revival, and I did find the Top a Secret StickyThread with a post on "waking up a sleeping engine" and I've decided that is the path I'll follow. My question is, how much compression is "good" for this motor? The service manual gives a pretty qualitative description of good compression, but I'm a numbers guy and got a gauge from auto zone and plugged it in. when I pull the rip cord each cylinder gets up to about 95psi. Is there hope for me?
Also; I couldn't see a spark in the new spark plugs as I was holding them by the boots and turning the flywheel, but it def felt like I was getting electrocuted!
I'm in no rush here, I'm in school all winter and this will hopefully be my study break project I can do a hour or two on here and there. I can upload pics but not until I get to the library, my phone isn't doing it this AM for some reason.
Thanks!
F_R
Honorary Supreme Mariner
It's your motor, and you can do what you want with it, but I would say it is a candidate for more serious inspection than what you are contemplating. Whatever way you go, I'll guarantee it needs new ignition coils. ALL Evinrudes from that era do, unless they have already been replaced. You can get new ones here at iboats.
I can also tell you that some of the 1955's had a serious design problem with the lower crankshaft seal. If you post your serial number, I can tell you if yours is affected or not.
Pitcherofnectar
Heres a pic of the serial plate, if I did the upload right
HighTrim
95 psi is fine on the Big Twins, especially one that has been sitting for that long. It will increase more as its ran.
Now, that is not to say that there is not more damage in the actual crank case, which would not show on a compression test, which is what FR fears. The good news is that a replacement powerhead would not be difficult to locate, they are fairly common motors.
For sure, you will need to pull the powerhead and go over the ignition.
Clean out the carb, and rebuild, with new fuel lines.
Drop the lower, and change the impeller. Inspect the grommets and other items and replace as needed. New o ring and grease on drive shaft splines before re installing.
Change the gear oil and new crush washers. Check it after a few outings for water intrusion.
Im sure you will have many questions along the way, don't worry about that. Lost of able bodies here to help!
F_R
You are in luck. Serial number 04803 is one of the good ones. Starting with SN #09501, they "improved" it with disasterous results.
Pitcherofnectar
Great news! Thank you for the help F_R and HighTrim, i will be asking plenty of questions for sure. Much appreciated.
I did see a powerhead listed on ebay, but with shipping it would be more than i paid for the motor in the first place.
i'm not against spending money on this project but I think i'll begin with the teardown/clean/rebuild method and go from there.
will update religiously as i proceed, but like i said i'll have an hour or two here and there between research and classes so it might be slow going.
thanks again!
82rude
Yours must be like this one here.Its a 53 25hp evinrude.The one thing I hated was the cowlng was screwed on ,not the clam shell which was way nicer.
Pitcherofnectar
That is a sweet looking motor. It looks a bit like mine. Here's a bit of an update: after a few days of trying I finally got the flywheel off so I can get to work overhauling the ignition. The components look near brand new, but there is sign of some green gunk on the contacts. I'll post a pic when I get to wifi tomm. I'm planning to just follow the original service manual and the listed steps for complete overhaul. Is that a good bet? I'd like to strip all the paint and rebuild from ground up. Can anyone recommend a solvent? Book recommends spirit of naptha, and I got a can of Chem dip for the carb. Thanks again for the help, gang!
Pitcherofnectar
Those scratch marks on the coils are from when I first put the bolts from the puller a bit too deep. Oops. Figured I'd prob be replacing those anyway?
The coils and condensers have been replaced.-----They are NOT the original factory ones.
bspeth
You will either have spark or you wont,if you have good spark no need to replace them.
lindy46
Dress the points with a point file or some fine wet-dry sandpaper, then clean them with acetone on a strip of business card stock. Set them to .020" when the rub-block is on the high point on the cam (usually coincides with the flywheel key). Then check spark with a gap-type spark tester, Should jump at least 1/4" with a snappy blue-white spark. If you have good spark, I'd call it good.
