Big tank or little tanks?
Lootas1
My old boat had a 23 gallon galvanized tank that looks good from the outside but had a bunch of rotten fuel in it. I blew it all out and put in a couple of gallons of fresh and drove the boat for 250 miles (on a trailer, that is) and blew the fuel out It came out looking as bad as the first go round. So, I cut the tank out today. (It was all foamed in). Now I'm wondering if it can be cleaned or if I'd do better to buy a new tank (not a rich man) or buy about three six gallon cans. That way I could mix just as much gas as I planned to use, and a little more, and not worry about the gas in the tank getting stale or having to add Stabil to it. Looking for your thoughts. If I keep the tank, how do I clean it? It does have a drain and I shot a bunch of PB Blaster but so far can't break it loose.
D
DJ
Guest
Re: Big tank or little tanks?
The portable tanks will be con venient but they will be in your way-on deck.
I would replace the in floor tank. With reasonable care it won't get as bad as the old one.
klos
Check out www.gastankrenu.com My company used to own one of these franchises. Its a process that bakes, defumes, sandblast inside and out and then is sealed with a plastisol coating inside and out. Works great for marine use and you will never have to pull that tank again.
dhatcher
klos that has been added to my fav's nice link there
Lootas1
Thanks all for your ideas. I have decided to take the tank to a radiator shop that cleans tanks. If they want too much money or find some flaw in my tank, I'll go with three 6 gallon tanks which will fit nicely under the splash well and take up the same space as the tank I pulled.
tashasdaddy
if you buy the plastic tanks, be sure to rinse them with a little gas, as the tend to have a few little particles of plastic in them from cutting the holes. i've used Walmarts tanks, without problem, just put a little teflon tape on the threads to cut down on air leaks.
