metriccrescentwrench
Thread starter- Joined
- Oct 22, 2007
- 2,598
I'm parting out my '90 Johnson 200 because, in my estimation, it would cost more than it's worth to properly repair. When I can afford to start looking for a replacement engine one of the considerations is going to be what can I bolt on with the least amount of work, so obviously a Johnson or Evinrude with the "big red plug" would be easiest. I guess worst case is I get my hands on an engine, wait around for the factory manual to arrive, and figure out the wiring (it would be nice to avoid having to pull too many more wires between the engine and dash). Hopefully someone here can educate me a little bit (with the understanding that I'll be going with another V6, probably either a 175 or 200).
1. In the diagrams on shop2.evinrude.com it looks like they stopped using that plug after 1995, is that correct?
2. Can anyone tell me what differences there are in the engines after '95 (both carb and fuel injected), as far as wiring and controls? (It appears that for the carb engines the power packs etc. are still essentially the same so I'd guess the wiring isn't much different).
