SHickey
Thread starter- Joined
- Apr 29, 2011
- 263
Hello,
I inherited a 65 rude 90 hp Starflite that had not been run in years. I mounted it to my Super Sport and with very little effort got the motor cranking BUT no spark. Bought a service manual for the engine and began diagnosing the problem (maybe a faulty coil or condenser). Pulled the distributor cap off to check points and gap. Tried removing the spark plug wires from the cap and guess what?? They were all corroded or rusted in the cap and I snapped some of the wires off leaving their ends inside the cap ruining the cap and the wires.
What should I do now?? I was reading about some owners converting their old ignition systems to newer electronic systems which are more reliable and less fussy. I am thinking that would be the way to go BUT there seems to be a number of electrical components in the "box" and on the motor and I'm not sure if I will be just dumping alot of money into this old motor with few results.
If I can get it running again, I'm not even sure if the electric shift works in the lower unit but I believe there is a way to test the lower unit without the motor actually running.
If any of you guys have an engine like this and believe it is worth salvaging, I would appreciate any advice/guidance you can give me. I am a little intimidated by electrical problems but I am willing to try to work out the challenges this motor is giving me so far.
Thanks again
Steve H.
Thanks again
Steve H.
