Better gas mileadge by changing propeller pitch?
lenny2113
On my twin 5.7 Mercs I run 14 1/4" x 17" pitch propeller.
The engine runs 4700rpm at WOT which I know is within the manual specs range.
If I were to change pitch to 19 or 20 would it be better on gas?
The boat is an old 26' Formuila deep-v and weights about 6500-7000 lbs.
Any advise is greatly appreciated.
Happy and safe boating season to all !
Don S
Re: Better gas mileadge by changing propeller pitch?
No it won't help milage, but it will overload your engine and cause excessive wear, it will make it a slooooooooow, process getting on plane, and you will probably see less fuel economy at lower speeds.
Keep the rpms in the rated WOT range for best results, and longest engine life.
lenny2113
Don S,
Thank you!
