Best Spot to Jack....
SteveRay
a single axle trailer for bearing inspection/repack :rolleyes: . I would also like to know in the unfortunate event that I have a blowout and need to make use of the spare tire
mlslocks
Re: Best Spot to Jack....
I try to jack under the axel close to or under the spring.
SteveRay
ON the actual axle itself?
mlslocks
Yes, as close to the spring as possible .
tommays
i allways carry a jack stand and wood chocks in my travel box because you can get flats in some places were the jacking surface is really bad and you need a lot of stuff to do it saftely<br /><br /><br />
<br /><br />tommays
jlinder
I like to have a block of wood between the frame and the jack. Keeps from scratching the frame, and seems to help reduce the chance of slipping.<br /><br />I notice that tommays picture shows an X wrench. Another great item to keep. Those lug nuts always seem to be much tighter when you need to loosen them.<br /><br />I would suggest you add a pair of gloves.
