best prop for mercruiser 120???
Echo720
Hi,
Just looking for some input on what would be the best prop size for a 1969 16' shasta dayboat. with a 120HP mercruiser with an m1 drive. right now its got a 16x17 three blade aluminum prop and doesn't seem to run correctly. engine at WOT is 3600 rpm... so what would you guys recommend
input??
Thank You
WillyBWright
Re: best prop for mercruiser 120???
I'd suggest looking at the motor. It should be easily capable of spinning a 17.
Echo720
perfect. i'll look at the motor or the tach then.
Thank You.
