Best bang for the buck
mh1042
All-
Have a 4.3 Volvo-Penta...carb....190 HP....192 Rinker Bowrider...14.15 X 19 prop..stock. Are there any simple mods to boost performance and HP.....I mean as simple as a high flow Air Filter? Or are there any reasonable engine mods to boost HP?
Re: Best bang for the buck
Nope,... Nothing for under a truckload of Money.....
oops!
with a 4.3............your best bet to increase your performance and fuel efficiency......is to leave any girls that dont look great in a bikini on the shore
mh1042
I'm 4600 at WOT...right in limits..about 50MPH with 400 lbs...47.0 with chicks included....
proshadetree
It takes massive horsepower and torque to notice it in a boat. 50mph gps if flying in that rig. If you need more power to pull tubes and skiers step down 2 props, more speed , dont think it will happen. cheaply.
mh1042
perfectly trimmed it has made 50 GPS...smooth as glass......47-48 usually top
mkast
You might try a stern jack an/or a two speed or shifting propeller.
If you look very closely at the prop, it's a two speed.
sethjon
All-
2 bbl or 4? What are you trying to accomplish? You might get awy with just a prop change.
mh1042
Its a 4 blade stock aluminum....I may just be fishing...just if there was something I was overlooking......
GLENN M
design of a hull dictates maximum speed once you hit it you can pour on the power and gain very very little,so unless your under powered your throwing money away.
starsnstripers
If you have a 2brl carb put a 4 on it. gains est. 15hp but more efficient at speed below opening up the secondaries Cruising just on plane. Also do you have trim tabs? They can help to an extent too on popular hull designs. Not a barge! lol
bnicov
Any gains you get would cost a small fortune. To pick up a couple of mph go with a 21pitch prop, BUT, you will lose acceleration and be slower to get on plane. Besides, running that fast only burns up a lot of fuel and REALLY wears out your motor quick.
GLENN M
i was just reading on the net about a guy who has been strapping rocket motors on just about everything.holds the speed record for a gocart 200 plus mph,he aint done a boat yet.
WSUDERMAN
Not sure what your looking fior Trailer boats Mag did a NOS test on a boat a couple of years ago with some very interesting results.
Joshua Nichols
Kinda spooky that everyone wants to go faster than 50... We had a bass boat when I was a kid that did 55 via the wish-o-meter.. We thought we was flying..
Here is a suggestion.. I saw a picklefork on E Bay the other day.. Jet drive, 502 blown/w NOS for 19k.. On the days you wanta be annoying run that.. On the days you want ski, tube and cruise run your 4.3...
Mischief Managed
This is only true of displacement hulls. Planing hulls gain speed linearly with the square of HP applied, there's no physical limit dictated by the hull shape (but obvious safety and structural limits). If he's reaching 47 MPH with 190 HP, he'll be able to reach 66 MPH by doubling the HP to 380, and 94 MPH by quadrupling the HP to 760. An increase of 20 HP will yield an addition 2.4 MPH.
Brucetafer
so what everbody is trying to say is nope....
enjoy what you have, and that it runs that well!!!!
Steve91T
I had that same engine in my 19 ft 2001 Larson bowrider. If I had kept the boat, I would have put a 4 brl carb, trim tabs, and a higher pitch SS prop.
Stock, I could hit right at 50 MPH per GPS with a light load. If I did the mods, not only would that increase the top speed by a couple of MPH, (53 MPH compared to 50 MPH is a noticeable difference), it would have had more low end tq, and probably a slightly more efficient cruise.
The SS prop would have been for cruising days, then the lower pitch Al. prop for wakeboarding/tubing.
There are a lot of people who say "get a 900 hp race boat if you want to go fast". I don't know why there are so many people opposed to increasing the hp slightly with what you have. The 4.3 is a fantastic engine. As long as you understand that making these changes is going to cost quite a bit of money, and is only going to give you a few MPH top end. But if you need to cover some ground and cruise at 40 MPH, with the above mods, you will do so more efficiently.
I see nothing wrong with it at all. It's your boat, and your money. I personally modify everything I own. I'm getting ready to purchase a boat with a 260 hp Merc. I already know what I need to do to get 300 hp out of it.
Just my opinion,
Steve
HT32BSX115
All-
You don't have an air filter.......
You could remove the 4 blade prop and replace with a stainless steel 3 blade of the "right" pitch. I.E. one that will give you right at the top rated WOT RPM..... 4800 etc.....
That will give you a little more top speed. It may not launch as good as with the 4 blade though. 4 blade props usually kill your top end a couple'a MPH.
Other than that, pull the V-6 and install a V-8.
I would take better "launch" over top speed any day!!
